sawood711
I purchased the Black Widow Go Kart made by ASW from someone locally and the engine was in bad shape. Instead of throwing the $30-50 into fixing it I decided to buy the HF Predator 212cc special for $99. The 30 series Comet clutch was pretty dirty and one of the springs was not there. In the rear pulley it has the green spring in it I believe. I am not sure what gears the sprockets are as well.
My question is what color spring(s) do I need to buy to replace the broken set? I am not sure what color spring would work the best with this engine to provide the best power output for my kart. Also, should I keep the green spring in the back or upgrade to the yellow/gold one?
I am mechanically inclined and use to race go karts back in the late 90's and early 2000's, but we didn't run this style clutch. Any help would be greatly appreciated on which spring to buy and how to achieve the best setup. At this time I am not looking for any performance mods just yet. I am trying to teach my daughter how to drive and maybe in a year or two I might step it up and rebuild the motor for more power.
