Poboy kartman
Senior Moments Member
The reason for not mixing the tappets (lifters) is that there is a spec for valve lash (gap). This lash is adjusted by grinding the valve stems until spec is met. If tappets are switched, this could (possibly) give you incorrect lash on both valves.
Possible. ...but not likely. ...they should be identical in factory form.....
The way to check is a feeler guage between cam lobes and tappets ....should be identical on the base circle.. ( when the valve is closed and the humpy part of the cam is 180° away from tappet).....check both. ...any variance. ..switch and check again. .....
You obviously want to assemble with the least variance...
In the future. ...always document and lable EVERYTHING on ANY engine so you can put it back together the same way. .....
