help tearing down?
The reason for not mixing the tappets (lifters) is that there is a spec for valve lash (gap). This lash is adjusted by grinding the valve stems until spec is met. If tappets are switched, this could (possibly) give you incorrect lash on both valves.
Possible. ...but not likely. ...they should be identical in factory form.....
The way to check is a feeler guage between cam lobes and tappets ....should be identical on the base circle.. ( when the valve is closed and the humpy part of the cam is 180° away from tappet).....check both. ...any variance. ..switch and check again. .....
You obviously want to assemble with the least variance...
In the future. ...always document and lable EVERYTHING on ANY engine so you can put it back together the same way. .....
carter
It's all apart now, all I have to do now is get ahold of some super 300, some 320 grit lapping coumpound, and a side cover gasket and I'll be good to go.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Thanks for the info.Maybe I will luck out on my placement during assembly.:surrender:
carter
Not as far as I'm aware :huh:
I coulda sworn I read that somewhere, I didn't see it when I looked again.
Maybe I read it in the racing mower page I go to, someone has a 16hp oppy and was gonna stroke it using an 18hp crank.
That makes sense; with the higher compression & regular unleaded, the engine will ping its head off (preignition), the higher octane premium will control that but, for a standard rebuild, regular is fine...
My mildly worked GX160 runs E10 (10% ethanol) just fine...
fowler
Bullsbrook West Aus
Probs should have posted pre disassembly
Made some roomy mistakes
Oh well too late now
Reinstall the side cover
Remove the flywheel by undoing the nut a few turns
Give it a few cracks with a soft hammer
Remove the sidecover again
Slide out crank and cam
Note the tinting marks on the gears
Install it as u reomoved it
Btw
U can replace the seals without removing anything from the engine
carter
I actually cannot see the timing mark on the crank because there's a giant ball bearing in the way.
I needed to inspect my internals anyway to make sure that I didn't damage anything when I ran it on low oil. Everything looks perfect though, looks like forking out the extra buck for that synthetic was a good move after all.
Now I'm just waiting for payday to lap the gasket surfaces for my head.
I'll just use a pick to feel for the timing mark, and use common sense to figure out where the dots should be. TDC of compression stroke with both valves closed.
