Help removing torque converter driven unit
The Noose
Oklahoma City
I was able to order a replacement cam for 20 bucks, do I'm actually glad I broke it. That thing wasn't budging. I used an entire can of pb blaster trying to loosen it up. It wasn't just a small burr keeping it from moving. Not the threaded part, but the part where the retaining clip attaches was jacked up pretty bad. The only other way I'd have been able to get that cam off would have been with an angle grinder, which would have probably ruined the cam and the shaft anyway.
AftER digging around a bit, I'm fairly certain this isn't a manco, but rather a yerf dog 3203. Seems there are plenty of parts sources for them. And plenty of people experienced in working on them too. So I should be able to get this thing flipped into a nice little rig.
If I could only get this jackshaft situation sorted out, I'd be on my way.
The Noose
Oklahoma City
Finally got the stupid thing off...
Finally!!! I spent a week straight, every evening for at least 3 hours a night trying to get that god forsaken torque converter off of the go kart, and today I finally succeeded...kinda.
I ended up having to get a dremel tool and cutting the nut off of the back end of the jack shaft. Then I used a hammer to knock the entire jackshaft out of the housing toward the driven side.
So with the jackshaft out of the housing and the stationary sheave still stuck in place on the jackshaft, I took a piece of steel pipe that had about 1" and 1/4" ID and set the shaft down into the pipe and used the hammer to force the shaft the rest of the way out. Once I got the shaft down flush with the sheave, I used a big center punch that I had laying around to push it the rest of the way out.
Had to order a new jack shaft and a new cam, but the rest of the torque converter seems to be in decent shape, except for the rust. I used a wire wheel on an angle grinder to clean as much of the rust off as I could. Nothing seems warped or pitted so I'm confident it will work fine.
$35 dollars for new buttons and spring for the driven.
$20 bucks for a new cam for the driven.
$20 bucks for a new belt.
$3 bucks for a bottle of PB blaster
$160 dollars for 20 hours of minimum wage labor which is all my labor is really worth when it comes to this stuff...
It cost me $238 dollars for a rusty 30 series comet TC that may or may not work properly.
Next time I am just going to use a cutting torch and buy a new torque converter.
