Help removing comet 40
carter
Hey friends I don't know if you're still up, but I need some help removing my comet 40(I'm pretty sure it's a comet 40, it holds my 10 hp engine, is a symmetric unit, and has no back plate). I removed the bolt from the shaft, then took off the snap ring, I don't know what to do now though, it won't move if I pull on it and I'm not sure where to go from here.
machinist@large
West Michigan, 49331
:useless: :useless:
We need to see what you have for an actual set up. Photos' also help us help you with trouble shooting. Basically, we need clear focused photo's of the problem area before we can try to help. And yes, many members have probably called it a night by now.
The only reason I'm on right now is because I work second shift.....
KartFab
Dallas, TX
I am going to make a video on how to disassemble, clean, and reassemble the 40 series. Hopefully over the weekend. :)
carter
I'm not 100% sure it's a 40 series anymore, looking at what you've shown vs what I've got, I don't know what it is, maybe you can help me ID it? Also, I don't know if these three screws need to come out, but the ring that they are holding has tabs that are bent on so they lock the three screws into place. How would I go about bending them back if so?
Sorry for the late reply and the no pics till now
carter
I just did some surfing, I'm almost 100% sure it's a comet 500 series.
EDIT: I got it off, I had to take a flat tip screw driver and a soft faced mallet to bend down the tabs preventing the screws from coming off, then when I pulled off the dome, it was really stuck, I got my handy puller and gave it a squeeze and it popped right off. It was rusted on there pretty good. Should I wire-wheel the shaft or just grease the bejesus out of it? Also the inside of the dome is filthy, I plan on wire wheeling that too.
EDIT 2: whole engine is apart, cylinder wall and rod both look good. While I'm in here though, can anyone point me to anything cheap I can do in here to increase performance, cams and whatnot? I'd like to stay governed because I hear tecumsehs don't like to be over-revved, but I'd like to get some more power.
