Help!!! Remove Rear Axle
nick956
Harlingen,Tx
Hello theres guys i've run into a setback which is i cant remove my wheels on my yerf dog 3203. the reason i want to is because i read another posts where this guy replaced his engine with a predator 212cc and he flipped the big sprocket on the axle and made it work with the predator without any other mods. Please help i want to get this summer project going already!!!!
We are going to need some pics, as well as an explanation egarding flipping the sprocket around. What is this supposed to achieve besides putting it on the other side of the kart
nick956
Harlingen,Tx
What i mean by flipping the big sprocket is literally face it 180 degress.
You need to get a lot of PB Blaster (or something) in there...
If you have a blowtorch, try Pat's (machinist@large) wax trick: heat up the axle near the wheel hub & run some wax into the joint...
machinist@large
West Michigan, 49331
:oops: Sorry, I can't claim credit for that one; someone else posted it (their name escapes me ATM), I just confirmed their sources as being on the up & up. And wax was just a part of the recipe; the problem I've just found is that the computer that I had that on is the one that died on me last fall:censored: I'll have to go troll thru the back posts again to get it back.......:surrender:
machinist@large
Penetrating oils
:idea2::wai: Found it!!!!! I just don't know how to link to it!!!:censored::mad2:
OK, to sum it up, it was posted by robbie on 2/12/2012 under penetrating oils (Other stuff, off topic fun). To sum it up, the top three penetrants tested by Practical Machinist magazine were;
3] Liquid Wrench
2] Kano Kroil (for three times the price!!!)
and 1] a 50/50 mixture of ATF and Acetone, well mixed.
The top three were all within about 5% of each other for effectiveness; I personally haven't had a chance to try the ATF/Acetone mix yet, but Liquid Wrench works well enough that I can't justify the cost difference for Kano Kroil. Kroil is a little better, but (for me at least) not three times the price better.
Hopefully this helps you out with the axle/sprocket swap.
:thumbsup::cheers2::popcorn: Pat
nick956
Harlingen,Tx
Im going to try liquid wrench becaus wd-40 is not working. And also im have a torch with a camping propane tank attached and its not working at all even banging the heck out of it it will not budge.
WD40 will wet it... & that's about all. Propane won't get it hot enough, especially if you're only heating the axle.
Get the liquid wrench into it & let it soak for a couple of days, frequently adding more
fowler
Bullsbrook West Aus
Soak it in PB blaster or deisel for a few days
Stand it on its end then fill the inside if the rim full of what ever u have
Then put the axle nut back on all the way till its just above the threads in the axle
This will protect the axle when u hit it
Then get someone to hold the tyre while u belt it
Or vise versa
This will only work with a big hammer like a gimpie or better a sledge hammer
It is definite u will be chasing it around the yard
realfast89gt
Kart Krazy!!
cibolo Tx
The last time I had this issue I soaked them in pb blaster and then drove the kart with the axle nuts backed off a few threads. This way it is still safe to drive, but the rims have a small amount of movement to break free. Obviously don't go top speed all out, just a lot of cornering and hopefully they will break loose. Worked great for me.
nick956
Harlingen,Tx
Would i be able to use nail remover that contains acetone or should i just go buy the quart one from lowe's for 4.95?
