If it were me I would get 2 more jets and go 1 size up on each. But yeah it's really close now. Does it start easy ? I know when I drilled my pilot it will start without he choke now and idle. So I know its rich.
In this summer weather I woukd want it a touch in the rich side. It will run a little cooler also
When cold, it starts on the first or second pull with choke on. I don't think it likes to start without the choke, but I have to flip it run quickly.
The 0.028" Low Jet, IIRC, allowed me to turn the fuel screw all the way in and the engine still ran. I'm almost positive this was with the muffler off, but think it was with the colder AR3910X plug.
I can steal the Low Jet from the 212cc carb and I will drill it to 0.027".
I'm 90% sure it fits in the 390 carb.
Not easy for me to find a 1.25 mm drill bit.
But the jet is here.... $5.45 + shipping
http://www.nrracing.com/product-p/99101-zh8-1250.htm
I bought this for $7 free shipping
http://www.ebay.com/itm/190828239150
New 15pc Micro-Drill Bit Mini Set High Speed Metric Sizes
1.05 mm -2.0 mm
15 High Speed Twist Drill Bits Great For Metal smiths, Metal Working & Drilling
Sizes: 1.05, 1.1, 1.15, 1.2, 1.25, 1.30, 1.35, 1.40, 1.45, 1.50, 1.60, 1.70, 1.80, 1.90, 2.00 mm.
What is the saying?
Give a man a misleading horse, or teach a fish to drink the water?
---------- Post added at 10:59 PM ---------- Previous post was at 10:14 PM ----------
And the bits shipped already. I also got a new $10 tachometer. These should be here in a month.
My next test will be with a larger idle (0.027 or 0.028") and the same 0.048" main jet (supposed to be 1.2mm, but HF products' QC is questionable). I measure 0.0475 - 0.0480". It came with two of that size. The other one measures 0.047". The HobbyTown USA 0.0465" bit measures 0.0465"
It makes labeling easy. 0.048, 0.047, 0.046, 0.045, 0.043, 0.042
I will try 0.048 and 0.028 (+0.002") with the AR3911 in the morning.
First I will test just the Idle circuit and transition.
I will start it and see how it starts. I'll try without the choke, then with the choke if needed.
I'll let it idle for 5 minutes and check the plug. Just looking at the tip, no cutting.
Then I'll drive it for 5 minutes at various throttle positions and test the transition and stuff.
Looking for No Hesitation / Bog / Stall.
Then I'll do the WOT runs and cut the plug.
This next $4 Test should teach me the most info per dollar out of all the plugs I sacrificed so far.pu
Also I need a big *** fuel tank. I may need to re-investigate the pump at some point. Or hang tank or shelf for a tank from the roll cage.
