We dont email replies here... Just fyi.
My guess(used to happen to my motor) is fuel is seaping past the float plug(due to pressure/gravity) n running down the "insulator plate"(black plastic plate between carb n head). I believe that was the main reason for the shut off valve under the choke arm.
I remedied my problem by installing a pulse pump(15$), n relocated my tank to a lower level, below the carb. This solved my fuel seaping out and gave me the wanted option of moving my tank to somewhere else more functionally/visually desireable.
Not sure what you mean by seizes up, but it 'could' be fuel is running down your cylinder n may be removing some lubracation?! Dont know...
