2 things you can do. Mine was super easy and fast. But had problems with the gov on a new motor.
You need to put a spring from the gov arm to the bolt that holds the ground wire on
Look at the pull start and right there it is.
Nice video from BuddyMasters
http://www.youtube.com/watch?v=OwshTzB3Roo
I had problems like I said I had to pull the gov out of the motor because it would surge bad like. When I looked at the gov before I pulled it Everything was really loose. That made up my mind to pull it.
Parts you will need.
Small U-Bolt Tractor Supply or Northern Tool around $2
Cable Tie Tractor Supply or Northern Tool around $3
Spring Napa $5 for a set of 5
And a 5/16-24 bolt 3/4 or 1" from ace hardware. under a buck
Some zip ties anywhere had them.
