help please with ackerman doesnt work
dalton
hello i have a few problems that i need advice on wtih my go kart im building .
i have my spindle arms line up with the center rear axle . however when i turn it seems the out side tire is slightly turning sharper totally reverse than ackerman.
and also when i turn it turns sharp inwards but doesnt turn sharp out wards at all.
any suggestions or advice ?
Umm- you have no componentry there... How do you know of the problem?
And FWIW- It's not the steering arms that must align with the strings- it's the holes for the rod ends.
dalton
thanks for the quick response
i have the angle set up so that the holes align , just n the picture the tires are turned a bit ,
but i have made a mock up of the steering components because im not sure what im going to do as far as it goes yet because it wasn't working , ( i do have longer tie rods just not pictured)
so this is the setup i used i thought the steering piece wasnt big enough so i made a new one wasnt the case
gokart14
Nebraska
guys you may need to back me up on this one (or i could be just seeing thigs) but with the way the two tie rods attach (i think) there is going to be more movment in one of the tie rods... I would try attaching both tie rods to oe piviot point (see this pis shows how they both attach to one point) this is just an idea to try i could be wrong so dont take my word for it but thats what i am seeing
lookig at the pics i am preety sure this is your problem
dalton
i tried this but maybe ill try a longer one
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Ding ding ding! Your absolutely correct. Dalton, you need to have both tie rods pivot from the same place.
dalton
ok thanks guys what about the rest of the frame you think it will work out good ? im not sure what kind of engine yet thinking 125 or 250cc dirt bike because it has clutch and gears
