Help please switches keep melting.
Rhodey
I've made an electric go kart for kids.
It's a 24v 240w motor,
2 sla 12v 7ah batteries wired in series.
Potentiometer speed control.
I had a 6 pin forward reverse switch, that melted.
Replaced the switch then the Hont Ht1007 switch from a drill I made into throttle pedal melted. Where am I going wrong?
EpsilonZero
...still cheaper than a boat!
There is too much amperage running through the switch if it is melting. You need a switch rated for more amperage or to use a relay that is rated for it.
Rhodey
How can i work out the amps that are running through to buy the right one?
Are you using an actual speed controller? :huh:
...or just different "switches"? :ack2:
A speed controller is designed/equipped to handle the amperage, your 24V motor is drawing
...most "switches" are not (that's why their burning out) :cheers2:
Something like this (~$30.00)
https://www.ebay.com/itm/500W-24V-D...192874?hash=item236db1526a:g:G3AAAOSwsWpeZA2g
