Help please! new go karts belt broke don't know what it is
kx100master
New jersey
Hi,
I just bought a go kart with a predator engine. There is some sort of centrifugal clutch set up hooked up to a belt. The little clutch thing has a piece that moves when u rev the engine. Well the belt is connected to another pulley type of thing but it doesn't look like a torque converter or a tav. The second pulley is connected to a chain which drives the wheels. The belt broke today and don't know why. I think maybe the front is a tav piece and the rear is not or something. Any help or ideas?
firemanjim
Just kartin' around....
Houston Texas
It's a jackshaft assembly with a belt clutch that drives a pulley. The pulley, in turn, drives the smaller sprocket connected to the wheel via a chain and bigger sprocket. Right?
With out pics, we really can't tell you why the belt broke other than maybe wear/age......
Post pics, and fill in your location. O yeah, :welcome2:
kx100master
New jersey
Ok I got pics but the belt doesn't look too old. Thanks for replying
well that's a Torque converter Driver and a fixed pulley on the jackshaft...
that can't work too well, since even if it is a series 20 driver you have the width and angles will either match the driver or the pulley.. not both.
Of course it did, the belt matches the pulley & not the driver, the driver is trying to close but the pulley won't let it, the weakest link is the belt...
What I suggest you do is replace the fixed pulley with a proper driven clutch & use the correct belt...
kx100master
New jersey
But isn't the piece like a cvt since it comes out. I thought those were supposed to be good. Could I just change the second part the pulley with like a tav piece
You need the driver and the driven to both be proper TC parts. As long as the 2 are meant to work together, you are fine. You cannot just use any old driven, you need one compatible with your driver
java230
Seattle WA
You need a driven pulley that will fit your axle, and a belt to match it and the driver.
So if that pulley fits your axle, yes that what your going for. But it needs to match the drive pulley.
kx100master
New jersey
How do I know what my driver is. Can't I just use any pulley thay fits and it would be fine
by what I can see of the driver I'd say it's either a series 20 comet or a maxtorque
i.e. symmetrical belt but that is just a guess...
kx100master
New jersey
Can someone help me figure out what converter it is I really need to know some people say 20 series and some 30
kx100master
New jersey
help pls torque converter keeps breaking belts need some help
Hi, I have a 212cc go kart with the harbor freght motor. The go kart Is a carter bros with a belt to Jackshaft set up. The driver is a torque converter part but the driven is not, it's just a pulley no springs or anything. I think I need a matching driven but don't know what my driver is. The belts I put on it keep breaking. Maybe I could get a whole torque converter setup but I don't know what I would do with the Jackshaft thing. Also I would like to keep my driver. Thanks in advance
Half-breeder
"Edit" button removed
Looks to be a 20 series. Take the driver off/apart n post pics. Maybe all that's needed is maintainance or a part. Pics of the driven too... tabs/inner spring pulley belt riden part. N an alignment shot to see if things line up.
