Help. New to go karts
Clgrein
Hi all. My 13 year old son. Bought a kart, an engine and a box of parts off of a friend. The engine is an Intek 190, 5.5hp. My question is...what is this on the shaft? Why is it there and how do I get it off? There aren’t any set screws on it. The clutch won’t go on with it there.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
It's a spacer. Why it's there is a mystery to me. You can try shooting it with PB Blaster a day before you try to get it off. You should probably put a short 5/16 fine thread bolt in the end if it looks like the puller might damage the threads.
Go to O'Reilly or Autozone and rent a puller ( if you don't own). The rental is free, you buy the tool, and get a 100% refund when you return it.
:welcome2: to the forum.
---------- Post added at 07:43 AM ---------- Previous post was at 06:50 AM ----------
Can we see a pic of the whole engine? It's kinda weird looking, like it might be vertical shaft.
anderkart
Surprise Arizona USA
Looks like that engine was on a Generator, and it probably has a tapered output shaft.
I'd suggest draining the engine oil first, then lay the engine on its side in a vice, (with the output shaft facing down) so the penetrating oil can work it's way into the back side of that 'spacer' for a few days. Then flip the engine over, and fill the center hole of that spacer with penetrating oil, and let it soak into that end for a few days before attempting to use a puller.
Clgrein
Here’s the whole engine.
anickode
S.E. Michigan
My bet is chipper shredder. Or possibly a water pump.
If that center hole goes all the way through as it should, you can tap it for 1/8" NPT and thread a grease zerk in there. With a lever style grease gun, pump grease in till you can't physically pump anymore, then tap the shaft with a hammer.
Clgrein
I remembered the pic, just forgot to hit the upload button. I’d remember the beer, just forget to pay for it lol. Yes the center hole goes all the way through.
