HELP! Need to get Yerf Dog 320 Running
f4atx
I bought a Yerf Dog 3203 for $100. It has no engine, clutch, or torque converter.
What is the most economical way to get this kart running.
I have already bought a 6.5 Predator engine from HF.
I'm looking at a "MaxTorque #40 10 Tooth 3/4" Bore Centrifugal Clutch Drum Housing Only Go Kart Mini Bike" for $22.
Will this clutch work?
What size sprocket & chain will I need?
Will I need to buy anything else?
Welcome to the forum
From the description, that "clutch" is only the outer housing which is useless without the business end. You need a complete clutch which will set you back around $35.
Did the kart have an axle sprocket fitted? If so, measure the distance between the teeth & the number of teeth & report back.
Pics would also help...
How tall are your tyres? How heavy are you? We will need some pics for sure. Did your kart have a jackshaft (we will know from pics)?
As far as I know, that Yerf Dog came standard with a comet 30 series, or TAV20. Going to a centrifugal clutch might necessitate a jackshaft to gear down far enough.
f4atx
Thanks for the replies
Sprocket has 60 Teeth and they are 1/2" apart.
Sprocket Part# 40A60
Tire are 19"
Will Post pics shortly
f4atx
additional pics
Blazkowiez
Kart Aficionado
Houston, Texas
You'll need a series 30 3/4" driver clutch. You can find them online between 60-100 dollars fairly easily. If you don't do something silly like drill new holes for that engine you'll be using a Comet 203591 belt or Rotary number 10052.
Well, no, you need to install the engine too :roflol:
But seriously, don't forget the chain... Make sure the teeth on the driven are the same as those on the axle sprocket (which sounds like a #41 pitch)
f4atx
Thanks for all the advice and info.
I ordered belt and driver clutch off ebay.
I'll post update when I get them in.
Kart Investment:
Go Kart $100
6.5 HF Engine $90+tax=$97.5
Rotary Belt 10052 $18
GO KART MINI BIKE 30 SERIES TORQUE CONVERTER CLUTCH DRIVER 3/4" BORE $47.50
TOTAL-$263
Dalascowbyfan
Dale Texas
Nice buy, Drum Brake w/ 19" cable. If Cable is in bad shape good luck with that. Not making them anymore. Had to modify my sons 3205 with hydraulic, and a rotor on the axel. But still all and all Good find.
jamyers
Buffalo Gap, TX
You'll also want to read up on cleaning / installing / maintaining your CVT, the FAQ / articles forum here has tons of good info. You might also check out my Yerfdog build thread in my sig for a step-by-step Predator-CVT install on my yerf.
Looks like you got a good deal all around, have fun!
