help me with my 125cc needs more power
armor117
OK so i pulled my go kart apart to day and iam just looking at building the motor up a bit before i put it back in it a 125cc pit bike motor what would you do if it was your motor
armor117
was thinking of putting a bbk i whan more power was hope some one on here can help
armor117
yer i know **** English my bad what valve springs, con rod, flywheel, exhaust carby what about a big bore kit
cumminsbayou4x4
fairhope alabama
if it had gears id rev it till i got the power i needed out of it but if it dont or you dont wanna float the valves put a uni air filter on it get a jet kit for the carb bore the motor out in it to like a 185cc it really depends on what you want to spend it may would be cheaper to just buy like a blaster or any other racing 4 wheelers i have seen blaster in runing condtion go for 800 dollors cause it will be right before hunting season and they want to get a utility 4 wheeler fast all the stuff to make it be faster will cost probilly more then buying what i said a racing 4 wheeler or any chain drive 4 wheeler for that matter
crazyman
Yorkville Il
Being a 125cc, it's more than likely a two stroke, fellas...
Air filter, jetting, (reed upgrade?) mild port job as per A graham bell's book, and expansion chamber...
armor117
it is a 4 stoke sorry guys can any one link me some parts and where to get the jets from
