I have nearly completed a minibike build using an old 8HP Briggs and Stratton engine from my father-in-law. Model number is 15432-0720-01 and it used to be on a blower.
Being brand new around here I'm hoping someone can help me figure out what is wrong with my governor setup. I've attached pictures for reference.
My issue is that I can't achieve smooth movement when using throttle cable. I can move into full tahrottle position, but it doesn't want to spring back on its own. The throttle cable of the blower was seized when I received it but the cable ending is the same Z type with a hole. It pulls on a slide built into the governor plate as you'll see in photo. All governor movement is normal to the best of my knowledge without attached springs/links. Engine operates if I move the throttle link directly at carb, just not with cable hooked to governor. I have a spring to connect the bent tab on governor plate to the governor arm on the engine. There was no spring between plate and carb when I received it, just a rod. Every setup I see online has a spring along with the linkage rod, should I purchase one? You'll notice the governor arm has a 2nd hold for what seems like could be a spring. Seems like it would help provide smoother accel/decel. Anything else that might be missing from the setup?
Greatly appreciate any guidance someone can provide.
Too light & it will not return, too strong & it may not open...
