02mx-5
I am buying a 6.5 clone and putting it in my doodlebug. I am going to remove the governor, and a rod, stiffer springs, header, airfilter, jet, flat top piston and a cam. Those are the first sets of mods to be done. After i will add a billet flywheel, better carb, better head and more.
My questions
What cam should i put in the engine for good low RPM power? I want torque off the line without sacrificing decent top end.
What do different ratio rocker arms do and what one are best with the cam you suggest?
What cylinder head is best for higher compression? Will i have to buy new valves for it?
What jet would you suggest?
My questions
