Help me identify this clutch
FredC
Hey gang, first post. I should start out by saying I am new to go karting and really don't know anything about engines except for righty tighty lefty Loosie LOL.
Anyways I just recently purchased a Birel Kart and I think I burn the clutch up but cannot find anything similar to it On Google. I'm guessing it's some type of centrifugal clutch? Also what would be a better more dependable with a better life expectancy replacement for casual riding around the yard with a 100 cc arc engine on a racing kart used casually for fun.
it doesn't get any more reliable than that..
yes it's a cetrifugal clutch
(in very bad shape)
I do hope you still have the rest of it, since there are missing quite a few parts ;)
If I'm seeing it correctly, that's an older Horstman clutch (DXL or "steel nytro" I assume but can't tell for sure)
Anyways.. Those clutches are for racing purpose only
as is your engine- it's not a fun kart engine
it needs a LOT of maintenance (every couple of hours [think 4-5hrs]).
and that usually means, there is no clutch available that is for the casual yard rider ;)
FredC
Hmm well those are pricey.. Go karting just might be to expensive a hobby for me lol. Those are a far cry from those $20 centrifugal clutches on eBay. . Oh well guess I'll either be sitting on a dead kart for a few more weeks or its starting to seem likely I need to get rid of this thing before I go bankrupt. Appreciate the quick replies.
I only removed the cover.
FredC
I just put the kart on Craigslist.. Lol not for me I guess. That might have been the most expensive cruise around the neighborhood I have ever made. I'll stick with my old John Deere that puppy is an all original 1977 JD 300 still pushing 140 lbs of compressions and starts right up no matter what..
Well gang thanks for all your help I don't think I will be hanging around a go kart forum much without a go kart. But thanks for the help, but it's apparent to me that I need to get out of this as I've already got way way way too much into it.. Wish I figured this out before I spent all my money on one of those Coleman starters and fixing those stupid breaks with no bleeder valves..
Im pretty sure a few of us wouldnt mind hearing about the JD... afew like tractors and other of motorized equipment... regardless of its "racing" potential.... or even if it moves under it own power...... it has a motor...... pretty much good to go.....
FredC
Actually it occurred to me I could easily swap the engine for a more traditional 2 cycle, not as fast but much more practical for playing around in the neighborhood and I'm guessing 30-35 ish is plenty quick for a typical back yard.. I only rode the kart a cpl times because it's an animal and a little loud for the neighborhood. I never intended to keep it anyways but I admit it's been fun and would hate to see it go.. Lol dang totally torn..
anderkart
Surprise Arizona USA
If you don't wanna give up quite yet yet:
You could email L&T: http://www.ltmfg.com/index.php?content=cotact a link to this thread, so they could see your clutch pic and verify its model #, then you could download its manual from their site.
I've seen some L&T clutch rebuild kits priced around $50 on ebay...
Or another option:
Clutches for a Yamaha KT100 engine will interchange on your ARC100. Several different companies made clutches for the KT100, so another option would be to shop around for a good used KT100 clutch... Only hitch is you'll discover these KT100 clutches come in either a Long, or Short Shaft versions. So you'd simply need to measure to verify if your engines output shaft is the long or shout output shaft version. This link has info to help you with that: http://www.kartingdirect.com.au/kar...kt100j-clubman-long-shaft-or-yamaha-j-10-13-t
PS:
For riding around smaller areas like your yard, try to find 9-tooth drive gear for your clutch, and also look into installing a larger (higher tooth count) axle sprocket to make your gearing more suitable. Like the 100-tooth Horstman #219 Split Sprocket sold here: http://www.out2win.com/catalog/sprkt_axle.html#2PC219
