Help identifing Tecumseh engine
tapkoote
north west USA
I couldn't find a thread
found a site with parts but no HP info
displacement says 195cc, I'd guess thats 5hp?
thanks
rmm727
Brookville, PA
Hmm. Somebody switch the recoil? Saw that on a generator one time. GX620 (I think that was the number) with a GX390 recoil.
Y'know- I WAS kinda stupefied- but everything seemed legit. Especially considering that the original owner had never done anything to it (at all... Including maintenance...:censored: )
But- who knows. In other brands, I've seen identical engines rated up to 1 1/2hp apart, in ONE case, just because of governed RPM. I didn't think TOO much of it. I recieved it as payment for maybe an hour's work, tuned it up, and flipped it for $200...
rmm727
Brookville, PA
Yeah, I don't remember what the differences are between the 5, the 5.5, the 6, and the 6.5. Thinking it was the stroke on the bigger two or three and the bore and stroke on the 5hp.
slideways
I believe its the bore size on the Tecumsehs. The 190 and 206 Inteks are the ones with the difference in stroke.
chrispyfur
Small engine manufacturers got into a lot of trouble a couple years ago due to over rating their engine output which ended up in a lawsuit. Shortly after that many small engines are rated in Ft-Lbs right on the recoil housing instead of HP. You'll see that a lot on push-mowers. Sad to say but a lot of times the only difference from one horsepower to another is either the size of the main jet in the carburetor or the sticker with the horsepower rating.
No doubt. I found exactly that when researching a certain breed of 2-stroke. IIRC it's the Briggs R*Tec that powers my little single-stage snowblower (which is reliable as he//, and I love to death). My EXACT engine, part for part, came rated from 5-6.5hp depending ONLY on factory-governed RPM.
