Help i.d. t/c and how to clean?
Raizor3203
So guys, I've been hangin around a little while and I've read a lot through your forums, but it takes a while to search for specific things. So right now, I'm having problems with the t/c and I've read on the go kart, and on this site that it should be cleaned after every 5 hours of riding. I think there's a sticky thread here that tells me how, but I do better with pics to help along the way, and there are none that I see on the first page of the thread.
So I'm working on this yerf dog cart, I've got the motor running pretty smoothly since I started working on it, but now I think I might be having problems with my clutch / t/c (whatever you want to call it) See it kept not wanting to go, so I checked the belt, and it was pretty much screwed, so I went to Advance Auto parts and they gave me a belt. The belt itself is the right length, but I'm not sure if it's the right width. It was about the same width as the worn out belt. I put the belt on, and at first it just wanted to eat through the belt, so we took it off rough ground and put it on flat even pavement.
Well... it would go, but it takes a while to get up to speed, but once it's up to speed it runs pretty **** good. After a while it seemed like it wouldn't bog down at all. While I was riding, I ran out of gas, so I put some gas in it, and started it up and went to go... And same problem again. It would move... But not fast at all. The belt looks good, not tore up so I don't think it's the belt. The t/c grabs the belt and starts to get going.... But then it's like it just slips the whole time. So I dunno where to go from here.
I also have no idea what t/c I have, so i brought you guys a pic.
I'm also attaching a pic in this thread of the chain. Two of the pins that hold the links together like to make contact with the driver. Any ideas on that one as well?
Thanks in advance for any help guys. I hope to have all the quirks worked out of this **** dog soon.
Edit: for the record, the asterisks are the other form of dam.
porsche930dude
Upstate, NY
that is definatly not the right belt auto parts stores wont have it. theres a chart somewhere that will tell you what you need. ill see if i can dig it up. for the chain just pull the link apart and flop it around so the pins stick out the other side where they wont hit anything
Raizor3203
On the new belt... Yeah it's almost like a V. I didn't take too much of a look at the old belt but I still have it. It's too dark now to do anything so I'll have to play with it in a couple days, but your link says I have to be logged in to use that site.
So basically, The symmetrical is the V and the A-symmetrical is the one with the flat side? I'm pretty sure it's A-symmetrical because on the old belt it does say that one side has to face the engine.
So whoo-hoo I bought a useless belt! :D
Your CVT is asymmetrical, and you did buy a completely useless belt. CVT belts have to be the exact correct length, profile, and width in order to function correctly. You must install the correct belt to even determine if your CVT is functioning correctly.
Raizor3203
So I believe that makes it a 30 series. I don't think I have the obsolete one and there are only two comets according to that link that use the A-symmetrical belt and one is obsolete....
Raizor3203
Ok landuse, I'm about to buy me a belt from your link. Thing is, there's two of them with slightly different measurements. Would this be a problem?
Raizor3203
Well either it turned out not to be a problem or I got the right one. But it's on the kart and now it's a completely different kart. I guess the first belt (Which I believe actually came with the kart) was just really worn out. I've been puttin the yerf dog through some thick **** in the woods and now I've worn out a kart trail complete with a little turn around I can drift.
Thanks for all the replies guys. I might hang around just keep gaining info incase I ever need it.
