HELP!!! go kart wont start
coolkarter
steinbach, manitoba
a while ago i took off my govenor and now when i tried 2 start it up yesterday it wuldnt start......i replaced the sparkplug but i think the problem is probely internal cause im getting good spark....its a powerfist 6.5hp(honda gx200 clone)
can anyone help?
r97
Measure twice cut once
Massachusetts, USA
has it bean in storage? i have heard that by passing the gov could do damage so actually removing it is much safer. is it getting a spark? does it run on choke?
KieranM
Doin It!!
Kilkenny, Ireland
do you have the basics needed for your engine to fire.
Spark----yes
petrol/gas
air
I take it that it has good compression, and since you didnt disturb it too much its probably something simple.
jareeB
I think your "bypass" method needs further explanation. Did you put the timing chain back on exactly aligned?
it doesnt have a timing chain it uses push rods. check the timing on your cam and crank line up the two little dots
