1992suburban
I wanna go FAST!!
Was running like a CHAMP then it quit like you killed the switch...
sooooo.. I trouble shot it real quick and.. NO SPARK... so I pulled the covers and flywheel. the key was sheared but was still holding the crank enough to turn over with pull cord..
installed new key... NOTHING
changed points, condensor, and coil.. fired right up then DIED..
NO SPARK
have not torn it back down to see if it sheared another key.. but if it did... will that cause coil, condensor failure.. soi that when you install new key it still wont spark????
HELP GUYS
NO SPARK
HELP GUYS
