Help finding rims
JA1905
Houston Texas
Can anybody lead me in the right direction to find 6" carter 2 piece rims part no G251 has 4 lug that fits flang hub 3/8" (G216) I have taken the wheels I have to 2 different tire shops and they cannot get the tire off the rim. Any help would be appreciated. Or any alternatives if I cannot find rim
Joe-405
Enjoying New Projects
U.S.A.
As a tire guy that has experience your tire shops aren’t trying to hard to get them off. Especially if they are 2 piece wheels. And Houston should have more than enough good tire shops that know better.
JA1905
Houston Texas
That's what I was thinking after the first shop but then the second place put some oil on them and kept them over night and still could not get them off the next day. I will try a third place. I looked online for the carter wheels and can't find them anywhere
numscul
Eastbay Area California
do you have to use that exact type ? is there another option of tire and rim you could use instead ?
If it is a 2 piece .... that means there is a tube ?
Need Pictures and more info
Texan
Senor Member
Deep In The Heart of Texas
I ran into the same problem as you. Carter wheels are not made anymore and have the odd 3-1/8" bolt pattern. They do pop up on ebay every once and awhile, but few and far between. Check out my thread here to see what I did http://www.diygokarts.com/vb/showthread.php?t=34607
So in short, cut the old tire to get access to the tire bead and snip it with some wire cutters, I salvaged my wheels and they've held up fine.
JA1905
Houston Texas
Texan thanks for the glimmer of hope, I was thinking the same exact thing, trying to cut them off. I will keep you updated on progress, will try to post pics if I figure that one out also lol
jandj
Williamsburg, Va
One thing I have done is shoot 'em good with PB Blaster and use several C-Clamps.
Get the round part of the clamp as close to the rim as you can and tighten the clamps a little bit at a time, shooting more PB in as you go.
Sometimes it works, sometimes you gotta cut 'em off.
JA1905
Houston Texas
here is some pics, I had to cut 'em off!!! had to use a angle grinder to cut through the bead.
---------- Post added at 06:48 AM ---------- Previous post was at 06:41 AM ----------
they look pretty bad, but I think with a little wire wheel action they should clean up well and still be salvageable
