Help Find Frame
Felipe.Gabriel
Hi, I want to start building a go-kart not so expensive, I'm having a hard time finding a frame to start my project. Can anyone help?
redflash
keep looking on craigslist..in every county within driving distance. I had to drive 4 hours each way for the first one a few years back.
but you might not be in the good old usa, maybe ? Or weld your own....many of us do that .
Da Flash
Know of any metals dealers/salvage yards within driving distance? A few sticks of 1" round or 1" square steel tubing would get you started on building your own frame, if you can weld and have the use of a cheap welding machine. Otherwise, redflash's idea on shopping Craigslist or something similar, maybe finding a rough-looking rusty frame for next to no cost, would end up being your cheaper way out. I'll attach some links that may be helpful to you............some free kart plans, a cheap house-current (120volt) welder like mine, and some parts dealers...............
Free Go Kart Plans, Kits, and Maintenance Tips - KartFab.com .................................. Ironton ARC80 Stick Welder with TIG function — Inverter, 120 Volt, 20–80 Amp Output | Northern Tool ...................................Go Kart Parts, Racing Go Kart Parts, Off-Road Go Karts, Drift Trikes and So Much More! (bmikarts.com) .......................................... Go Kart Parts | Go-Kart Part | Go Kart Kits | Mini Bike Kits| (gopowersports.com).......................................
Snowmobile Parts, Go Kart Parts, Lawnmower Parts, ATV Parts, and more | MFG Supply ........................................Go Kart Parts | Mini Bike Parts | Clutches (gokartsupply.com) ..........................................Go-Kart Frame with Steering Hoop | AZ3502 | BMI Karts And Parts
Sure we can help you out. But you have to answer some questions for us first! Can you weld? What will the kart be used for? Are you handy with tools? Do you have any tools?
Felipe.Gabriel
No, I can't weld, and im in high school and I'm planning to build the go-kart as a project to help me get into college for mechanical engineering. I can use tools I'm good with them, and if I need I can also go buy some tools.
Felipe.Gabriel
I Found this one near me, but idk if the rust in the go-kart will affect its durability and it would still work. And if you know how to clean it, it would be helpful. I don't know how to clean it as well.
Very hard to tell how bad the rust is from your picture. Hard to imagine it is so bad that the frame would be structurally compromised. Ways to remove rust include a product called Navel Jelly which will remove the surface rust. After that it would be a wire brush on a drill and then sandpaper and lots and lots of elbow grease. If you have the access and the money sand blasting the frame
AFTER removing all the parts would be the quickest and most effective.
If you can look it over before purchase, look for cracks (in the frame)
...& also, look for "flat spots" underneath from scraping on the ground
If it looks structurally sound & you can get it for a good price, go for it :cheers2:
Surface rust can be easily removed by hand (like Pancho mentioned) with sand paper :thumbsup:
Utsavvp
I wanna build my own kart i have tools and everything just need a design can you suggest
Utsavvp: Click on GoKart Discussion at home page to bring up this part of the forum. There's a blank top line for you to type in a heading for your own thread. Just type your question, put an explanation in the body of it, and post it. Somebody will help you out.
