HELP! Can't get my spring on my driven unit right
Webug904
Not sure what I'm doing wrong. There is no hole to seat the spring by the buttons. I don't not what to do and I have to have this kart finished before Christmas
Bbqjoe
Banned
Location, Location
Relax man. I'm sure we can get this figured out in the next 15 days.
Take a bunch of pics of what you have, post them, and then we can all talk.
Webug904
So the problem I have is all the videos I find show a hole in the part the belt rides on the seat the spring. Mine does not have that. And my spring has one end that is flat while there's both have points
a maxtorque torque converter...
Anywhoo..
pretty straight forward actually..
put the spring (just oriented as it sits on the table) onto the TC shaft
allow the protruding arm to catch in one of the three valleys (it does not matter which one)
now place the cam (the one that's marked with the Maxtorque name) on top, thread the protruding end of the spring in one of the three holes...
(1 for shorter torque and quick upshift, three for slow shift and thus longer torque operation, or the center one for almost all normal riding)
NOW turn the cam clockwise to tension the spring (preloading it)
make sure nothing else turns underneath it (i.e. tightly grap the moveable sheave [the part with the rubber button-cam]
so that it jumps over one "bump" of the cam into the next valley.
press down and secure with the snapring you should have.
and you're done!
BUT that spring looks worn to me.. contact maxtorque for a replacement,
they're quick and happy to help.. I'm nearly certain they'll ship fast enough for you to have it before christmas.
ALSO be aware that MT TC are symmetric, and you have a straight wound spring, thus the cam needs to point INBOARD (towards the engine, NOT towards the wheels!)
Webug904
It doesn't seem to preload right. Maybe because it's worn. Also the cam has 4 settings on it.
Webug904
Any you guys able to explain how I pull this axel to replace the bearings?
Webug904
I got it out
---------- Post added at 12:29 PM ---------- Previous post was at 12:28 PM ----------
Just needed some muscle
