Hello from FL
IMJUSTWINDELL
FL
I've been snooping around on this page for a while looking for ideas for a go kart and I finally got one so I wanted to share my kart and my ideas see what I can learn from all of yall so please give me some tips and tricks I would really appreciate it. I've made a list of parts I need to get for it but don't be afraid to give me your opinion, (p.s) I have no clue what frame it is lol and I want to get rid of the whacky engine riser.
I've ordered EN904.2 rebuild kit for the master cylinder and also MCP1375SE-BW for the brake caliper plus pads for it from (kart-o-rama)
I have a predator 212c (gov delete) with a maikuni 24mm carb, ARC billet flywheel and ARC billet connecting rod.
I want to ditch the gravity fed fuel set up and get a fuel pump and a proper fuel tank.
The torque converter is junk so I've been deciding if I should get another one or get a centrifugal clutch.(not really sure on which one is better)
The tire sizes in the rear are really hard to find so I have to figure that one out but that's kind of it for my kart
With 10 and 12" tires, and the fact that it is a smooth track style kart, you don't need a torque converter. If you plan to try and use it off road ( good luck ) then you probably want a torque converter. Welcome to the forum.
