header?
kendelrk
redneck engineer
westland michigan
im getting a header for my honda clone, how much hp gain can i get from a header? and how much with a k&n air filter on it?
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
It wont be huge, but slightly noticeable. The header & filter go hand-in-hand. You'll also need to rejet your carb.
kendelrk
redneck engineer
westland michigan
I have a number 90 main jet I heard that after you rejet and get your airfilter and header the Honda clones give out a lot more power
slideways
About 1hp or so gain. Its noticeable in most cases. The motor pulls harder through the midrange area and is alot smoother and responsive.
For most people this is all they need and they overbuild their motors. Or they start building them and give up because they can't finish them or get them to work right afterwards.
slideways
Not really. Its illegal in most rulebooks because they just don't want people playing around in there. But its so minimal that i wouldn't even bother to take the effort to pull the shroud and do it.
After you do your intake/header/jet.. wouldn't be a bad idea to get a 4 degree advance key for your flywheel.
Bluethunder3320
someone told me once to cut fins off the flywheel. i doubt it takes any power to turn that fan at all, so why sacrafice the cooling of your engine to make it last longer?
kendelrk
redneck engineer
westland michigan
i heard it reduced drag and gave about a 1/4 hp increase, and where would i get that and about how much would that cost? and wheres it at in the engine?
Cutting every alternate fin off would reduce drag. I doubt you'd get 1/4 hp from it, but who knows. As far as the advanced flywheel key, well... The flywheel!
Advanced timing keys can be bought online at various kart supply places. It re-indexes the flywheel to advance the ignition timing by a predetermined number of degrees.
redsox985
PA
You won't get a ton more HP from this motor unless you put a considerably large sum of money into it. You can get more RPMs, and some HP from intake and exhaust, but to reap the full benefits, you need to overhaul the guts which isn't exactly cheap.
