Head Scratcher
AZBoy520
Tucson Arizona
Hello Everyone
Need some Input, I want to remove the govenor from a couple go kart engines I want to build. Here is where I am stumped, I have been told that if you remove the govenor, that you should replace the flywheel because it will blow up, correct me if I am wrong but wouldn't the connecting rod go before the flywheel? I mean the flywheel is solid metal and i just don't see how it would break before the con-rod. I am thinking it is possible to save $100 by just getting a billet connecting rod and running it in conjuction with the stock flywheel and crankshaft, vs buying a billet flywheel and con-rod.
Thanks In Advance For Your Inputs
firemanjim
Just kartin' around....
Houston Texas
If you're gonna go past 5800 rpm for long extended romp sessions, get the flywheel too.... If not, billet con rod should suffice. You can always limit your throttle so you don't go past a set rpm.....
:oops::welcome2::wai:
Half-breeder
"Edit" button removed
Hello Everyone
From what Ive seen/read...
Yes, flywheels have been known to 'explode' at times, mainly at high RPMs. You are correct in saying that the conrod should give before the flywheel... but, the valves will float(if the factory springs are left stock), before the conrod would break(unless it's past the expiration date... then youre playin Russian roulette :2guns: w/ your piston/rings/cylinder/etc).
I agree... get the 'Billit' conrod, if not for future necessities, but for the sheer ethics of getting one. Ive hear that w/ the Billit conrods the oil sensor 'unit' needs to be removed... but that's just what I 'hear'.
...and IMO, anything more done to the engine past the intake/header/jet/+.020 pistons/rings, gx160 head... is borderline pushin the limits of the motor for longevity.... and yes taking out the governor is a BIG segment deleted from alotta motor's life span's.
Half-breeder
Thanks FiremanJim
Curious, what exactly happens with a stock flywheel past 5800, does it warp itself?
... a hairline fracture forms during an apex stress point of a revolution. Shortly there after(due to the hardness of the metal), the flywheel will technically 'shatter', sorta like glass, but because it was spinning at whatever +5800 rpm... the effect is an explosion... plus i hear its kinda loud too. hehe
AZBoy520
Tucson Arizona
Thanks Guys
I saw someone selling a race kit on ebay for the predator 212 that included a PVL flywheel but according to NR Racing PVL doesn't make a flywheel for the predator yet
Am I missing something
Scout
Nutjob
Indiana
I put a billet rod in my predator and did have to remove the oil sensor. I put a screw in the rubber grommet where the wire came out.
redsox985
PA
If all you do is pull the governor, you'll likely float the valves before anything goes boom. Stock valve springs aren't any more than "sufficient" for their intended speeds.
