Ok, so I have a Robin Subaru EX17 (169cc) engine and I took the cylinder head off and the head gasket, it's an all metal head gasket. I remember seeing this dark gray stuff on it, thought it was carbon build up, so I scrapped it off. After I put everything back on and made sure that the ignition and valve timing was PERFECT. Go to pull start it... nothing, check the ignition and valve timing again, nope still perfect and where it should be. And everytime I pull start it, it's really easy to pull. So it probably has no compression, I come to realize now, that the "gray stuff" I scrapped off was a gasket sealant which is most likely why it has no compression. Do you guys have any idea as to where I can get some head gasket sealant to apply to the head gasket itself???
