Hawg-TY 10hp diesel mini bike & pics
porsche930dude
Upstate, NY
cool! make sure you line up the sprockets without the chain on it because it can be very deceiving. crouching at the back of the bike looking forward across the sprocket twords the clutch. I also agree your gearing is way too high. try 5:1 and see how it goes. you need to run it in the range its designed for. you certainly shouldnt be going over 40 on that thing anyway. but the way youve got it geared itll probrobly do 60
porsche930dude
Upstate, NY
heres a street legal one. as you can see he has a torque converter
numscul
Eastbay Area California
a few pics of the finished mini bike
here are a few more pics
Famvirs
Banned
Eritrea
order priligy
Common use - Dapoxetine belongs to a class of selective serotonin reuptake inhibitors (SSRIs). This short-acting inhibitor is used to treat premature ejaculation in men.
I am ready to accept the situation that customer support sometimes can be dull when I want to trace my order plus order priligy
I take priligy pill and it works as expected but after sexual intercourse I sometimes feel muscle pain in the back and fatigue. I do not know if this is because I work like a stud or it is a side effect. Anyway I am lucky that I gave it a try.
numscul
So far iv got the mini bike up to about 56mph or 90.12kph it still wants to go faster but im
not so sure i want to go any faster ...It seems like when i hit about 35mph i get a little boost almost like the clutch is fully engaging ........
numscul
Ok ....after i posted the pics earlier today i took the mini bike out for a ride and as i got up to about 50mph the chain popped off ...........So i took the whole thing apart "every nut and ever bolt and i found that the engine has been mounted slightly off only about 1/8th of an inch .....Is their anyone who has had this problem before ....And what did you do to fix it .....im thinking about making the mounting holes elongated so i can slide the engine into the correct place ....But what holes do i need to elongate to do this.....
Jcotz
...wasn't there
NY
For me, I had chronic problems with my chain falling off. My solution was to take all possible slack out of the chain. This worked, but I think may be bad for the clutch.
Badot
If the chain is misaligned adding more tension can easily do major damage.
Which way is it off -- can you just slide the clutch out a little farther on the shaft?
I would elongate the holes to allow movement and to make adjustments. Use a straight edge to check alignment.
numscul
HA HA ....Well i got it put back together just in time for my mom to come home and tell me
she F@>K&N hates it the foot pegs are to far out ....The handle bars don't come out far enough ......The seat hurts her *** ......and she HATES IT ........HA HA .... AND THATS THE THANKS I GET
Great!! Now you get to keep it yourself..
