having trouble with my clutch still...
happy_8637
Elkins, WV
so i was slightly lacking of power before and i dont really have the money to get a bigger engine so i found some smaller tires at TSC. they are 16-6.50x8 i took off 18-9.50x8. I gained a decent amount of power can rip donuts now when before i couldnt. so i got on my android and downloaded a gps and said i was running 35mph, then i went to the afgk.com website and typed in how fast i was running and the gear ratio and started playing with the rpm and found that i was only hitting 4400 rpm and i have the gov removed, header and intake and rejetted. I even bought the"yellow" spring for the secondary and tried all three holes on the clutch and then i went back to stock and tried all three and i ended up staying with the yellow in the first hole was the fastest.
solomon
ca
is it running rich? whats the plug look like? WHy do you think its the clutch?
Half-breeder
"Edit" button removed
From my experiences dealing w/ TC and top speed not calculating up... depending the gear ratio, it could be your motor just isnt strong enough on the topend to turn the 16" wheels to top speed. Or... it is possible that the copper ring on the driver is restricting the driver to open all the way(my ring somehow got cockeyed and got stuck in the driver clutch slide... preventing me from reaching the calculated speed.
Also, another thing could be 'mis-calculation'... let me explain... 16" wheels(2-ply) w/ ~250lbs tend to sink bout .5", making the wheel actually a 15" rolling diameter.
happy_8637
Elkins, WV
checked the plug golden brown. looks good otherwise. ill check the ring on the driver might be the problem. same carts one with a cc and the other with tc and 2 inch taller tires it makes me turn towards the clutch.
the difference in 1 inch of a difference in tire size is like 300 rpm still should make a bigger difference than that
happy_8637
Elkins, WV
well i took the driver off yesterday and it was dirty inside.. so i knocked the dust out of it and then put it back on and made sure the bushing was straight. i put some oil on the thing that the inside piece slides on gained an extra 3 mph. it wasnt closing completely, and didnt slide freely and then i ordered some 1.2:1rocker arms and 18lb springs so hopefully that gets here and gets more a little more push. oh and where can i find that dry lubricant stuff from the parts store autozone or orileys maybe thanks
