Has anyone here polished their engine?
Bbqjoe
Banned
Location, Location
Merely for aesthetics. If so, how did it come out, and or last?
I'm thinking for whatever reason, the next time I tear my engine down I might polish it just to get a nice chromed look.
Joe-405
Enjoying New Projects
U.S.A.
They make a high temp.coating that looks like chrome. Much easier and more durable.
We have a product that might make it easier to get an engine to shine ..
I'm fairly ccertain you'll have that too called Alu-Magic
Anyways, a rub'n'buff.. apply, wait until it turns dark and rub it of with a soft cloth...
never tested that on an engine block of course but even cast aluminium (which I guess holds true for an engine block ;))
will become shiny (not smooth though)
but if that's all you're after it'll still takes some of those tedious labor off your chest ;)
PS if you have an aircompressor handy, try to soda blast the engine first...
It'll takes some doing.... But if you have some patience... It'll look good...
I like autosol metal polish... Usually comes in a tube, but can find in bigger cans...
It's also made in Germany.
Joe-405
U.S.A.
Cool Mang. I'll try it.:cool:
Do you have a link or a suggested product?
I was referring to a coating place that does the header stuff. Was hoping you had somebody local.
But yeah for aesthetics wise you could try it by hand but it's a pain trying to get in the cracks corners and between the fins.
Flyinhillbilly
The great cornholio
North West Arkansas
Furthermore, it will reduce cooling if you polish the fins. More surface area = better cooling.
I've polished a lot of aluminum, and I usually start with a roloc scotch brite disk and take the texture out of it, then wet sand with 220, 600, 1500, then 3000. Then I use a wool pad with rubbing compound to bring it to a shine, then I buff it with mothers or never dull, and it will shine like a diamond in a goats behind.
well you could always just smooth polish the outer faces (or rather edges) of the fins and leave all the in between surfaces dull'ish (surface texture) and just shine them up it with ..a buffing wheel or...well alu-magic ;) the latter being even less abbrasive...
That way I doubt you'd reduce the cooling by any measurable amount.
And while a mirror finish might look awesome in a showroom or garage.. frankly...
sticks and stones on the gravel road and it'll have visible dents in no time.. and you need to repolish again and again and again...
personally I'd go for the least amount of work to make it look clean and shiny
so that small scratches do not catch anyone's attention and in case some major scratch is... it'd be easier to remove.
After all it's a work horse, not a indoor show bike..
jm2c ;)
Flyinhillbilly
The great cornholio
North West Arkansas
^^^ he's right on point. I'm not usually working on minibikes, and tend to take things further than would be practical on a minibike.
There are people that go as far as having a very tiny diamond pattern vin into the edges of the fins on some air cooled motorcycles. They claim it makes them run cooler.
Flyinhillbilly
The great cornholio
North West Arkansas
In that case, yeah, polish away. I understand that for sure. This is one of my old bikes. First one I built from scratch.
Staff Murderator
There's a science to rake and trail.
Indeed, and that front fork is not the most radical in length that I've seen. In fact, that one is rather conservative and functional looking.
Bar-B-Que: I recently polished the combustion chamber area on my cylinder head. It always starts small with me--like at first, I was only going to use sandpaper but then I wondered if I had any felt pads and more importantly any jeweler's rouge on hand. I did, and happily set about polishing the thing up mirror smooth or as close as I felt like it.
First I knocked down as much of the "grain" texture on the aluminum as I could with various medium/fine grades of sandpaper (400-600 grit). As soon as I started with the Dremel felt disc and rouge (polishing compound), it really started coming alive...
P.S. I could do more and really eliminate all imperfections but for functionality, a polished chamber is going to enhance combustion and flow but only to a slight degree. I'm thinking it will greatly simplify the removal of carbon buildup from its polished surface.
My Pulsa-Jet carb is presently getting the bling polish treatment. I didn't want to paint it because carb cleaner has a fatal effect on paint.
Bbqjoe
Banned
Location, Location
That looks really nice!
I might consider doing all that the next time the engine is out, or if I run out of things to do.
