Harbor Freight's predator engines
JHen
Anyone know anything about the new engine line Harbor Freight is came out with?
r97
Measure twice cut once
Massachusetts, USA
An opinion...
I think you will find that they are not very far different from the clones we are used to.
Same crap...altered cosmetics.
:iagree: new tank, air box, recoil, color scheme, and a slightly better block. maybe more EPA crap.
r97
Massachusetts, USA
IIRC, it says something along the lines of "precision machined block", and i don't remember that on the old ones. i think sideways also said the blocks were better. they probably just run the block over with a wire bush or use slightly better sand for casting, and check every 999th engine for "quality" (cough cough) instead of every 1,000th engine. :roflol:
___________________________________________
as far as new engines, i still don't think you can beet the deals on subies! 6hp, $220, free shipping, and some of the strongest and best designed parts in the biz! not a ton of mods, but most of us (who even mod the engine) only remove gov, add pipe, and air filter. if you built a kart you can do those easy! if one clone breaks and you have to buy another, you could of had a subie!
http://robinamerica.com/pfeatures.aspx?pid=8
http://cgi.ebay.com/Robin-Subaru-En...987?pt=LH_DefaultDomain_0&hash=item45fb6aa623
http://cgi.ebay.com/Robin-Subaru-En...282?pt=LH_DefaultDomain_0&hash=item45fb1b9902
JHen
Hmm, those subaru engines do look enticing. Overhead cam is really neat.
JHen
Only thing wrong with those subaru engines, they are all in METRIC. I despise mixing Imperial and Metric on the same machine.
slideways
There are also no "hot rod" parts for them. Parts in general are hard to find. You won't go down to a local mower shop and expect to get an air filter for a Robin Subaru. Or a valve cover.. or a drain plug etc...
JHen
Well, I went and got one today, the 212cc model. From the research I did, it seems like everyone is just waiting around for someone to take the plunge. I decided to do that and I will video document my inspection process. Got it for 150 + tax and a 2 year replacement warranty for free.
Also picked up a dial indicator so I can measure my drill press' run out to see how horrible it is.
JHen
Well, I pulled open the case and I was disappointed. It has a plastic cam gear. Though, the gears are helical gears which is good.
I think it will probably hold up ok under normal power, but if it were to be spiked under some high power it might eat up the gear a little bit. The governor is in the top left corner there and the low oil sensor is the black bit under the crank.
They also drill out the crank shaft where the rod connects to, to save weight I'm assuming. I'm not sure if this is standard practice in small engines. I don't for see it really being a problem though.
The fly wheel is too parts, the cast iron wheel bit for the weight and then a plastic part that is the fins for the air blower.
I pulled the low oil sensor out, which can be done without removing the cam shaft I think, but I took it out anyways. After I got it all back together and put oil and gas in it, it started right up. At low speed it had a kind of kick to it, which I'm assuming is the power strokes, but if you gave it a little gas it steadied out pretty good. Now I just need something I can bolt it to for like 3 hours to break it in lol.
All of the machined surfaces looked pretty good from what I can remember. The lifter rods seem kind of puny to me as they are only about 1/8" I think.
JHen
Their just doing what all other manufacturers are doing. No one (as yet) can tell me why this is a problem.
I'll take a plastic cam over steel any day.
Why so? I suppose that if it is properly lubricated and cool (relatively), it would take a while to wear. Gears, good ones anyways, are typically made of a hardened alloy so as to reduce wear on it. Also, if you were to increase the valve spring strength, the plastic may not be able to hold up under the extra force and break or bend or some other undesirable effect.
