Harbor Freight predator 212cc governor
trooper3455
Tennessee
Hey guys, anybody know how to adjust the governor on my predator motor to get more power I don't want to remove it if I dont have too just open it up a bit.
Jcotz
...wasn't there
NY
Technically, yes he will gain some horsepower, as Torque*Rpm's=Hp
While technically that may be true, "power" in the above context has a tendency to refer to torque. For the purposes of a "Seat of the pants" description, an increase in max RPM equates to an increase in top speed with no noticeable power difference.
The neat bit- One could FEEL more power with a governor removal by gearing down slightly. Acceleration will improve without sacrificing top speed.
Swabbster
just remove the governor, when i do it i pull the shroud off pull the flywheel and nock the stud out, then open up the side over take all the bits out and take the clip off the stud and pound it back in, put it back together and your done, also not that you will need to move the governor arm out of the way to knock the stud out
Have a look at the hand throttle on the engine (the lever you would normally move to speed up or slow down the engine). Behind that lever should be a screw that the lever stops against. That is the governor adjust screw. Backing that screw out will increase governed maximum RPM. Should get you up to about 4000RPM.
scarletvw
Minnesota
I accidentally found out about that when I mashed down my throttle and it bent the stop and made the screw useless :roflol:
