trooper3455
Hey guys, anybody know how to adjust the governor on my predator motor to get more power I don't want to remove it if I dont have too just open it up a bit.
Have a look at the hand throttle on the engine (the lever you would normally move to speed up or slow down the engine). Behind that lever should be a screw that the lever stops against. That is the governor adjust screw. Backing that screw out will increase governed maximum RPM. Should get you up to about 4000RPM.
I accidentally found out about that when I mashed down my throttle and it bent the stop and made the screw useless![]()
Two words... "Pedal stop".
