Harbor freight motor. 212 cc
Tboy30
I just recently just bought 2 of the preator motors from harbor freight. I put them on my go karts for my boys and for some reason they run for awhile but die. You can restart them and they run for awhile. I'm confused on this. I changed the spark plug in them. Oil is good. Idk. Help.
rocketkart
florida
there is a oil Sensor on that engine you need to disconnect. All it does is ground out the coil when the little float in the case gets low (such as in the curves). So look for the wire coming out of the front of the case and disconnect it from the wiring for your shut off switch. You can cut it but if you do and that wire touches anything metal it will shut the motor off. www.youtube.com/watch?v=bhiY7Mbe3oE
Scout
Nutjob
Indiana
Or you can try loosening the gas cap a half turn. I've seen where that causes the carb to not fill.
