You could also use a small spring to connect your throttle cable to the butterfly, so that when you mash it, the spring will absorb any shock. This will require a little fooling around. Too weak, you'll experience a lag in the throttle, maybe a bounce. Too strong, you lose the shock absorption. Or, you can do it Nerfo's way, I see no problem with it.
