Harbor Freight Clone
EagleTalons
Master JB Welder
Forsyth, Montana
I've been waiting for my clone which is on back order... So I got bored and messaged them...Here is their response.
Your order currently shows item # 66015 is on back order. At this time,we do not have an estimated date as to when it will be coming in. You will be receiving a card informing you of the back order date once the vendor supplies it to us. We apologize for any inconvenience this situation has caused and hope to have your order shipped as soon as possible.
Grrr! Anyone else currently have this problem? I ordered mine around the 21st of May...
The GC kinda discolors my pant legs because of the exhaust facing forward...
Kaptain Krunch
Pro Junk Collector
vermont
If i had a doodle bug, and a sled engine i'd do it, i mean it probably would just flip over at the blip of the throttle, but atleast if you ever get going you'll be able to beat any other minibike on the block :roflol:
EagleTalons
Master JB Welder
Forsyth, Montana
Meh...maybe a Arctic Cat Kitty Kat engine. :p I went to my engine storage place (2nd floor barn) and noticed a 5HP briggs! Connected onto a broken water pump. So, I'm prying the plastic pump off. It's still stuck...sprayed with some liquid wrench and left under pressure. So hopefully I'll have that one to play with. Should have better torque and it has a nice throttle hookup on it!
Kaptain Krunch
Pro Junk Collector
vermont
So why are you buying a clone when you got a perfect flatty?
I would just cancel the clone and mod that, there endless things you can do for power on a 5hp flatty.
Kaptain Krunch
Pro Junk Collector
vermont
I don't know if this engine runs yet. Plus it's really heavy.
Duck tape will fix anything, and tie like 10 helium balloons to it and it will be much lighter :roflol:
On the serious side, you should make a kart or something with that flathead, there nice engines. I got one sitting in my shed right now off a tiller, just need to clean the carb out and remove the governor (it doesnt have linkage).
jetlag
Memphis, TN
A friend of mine just ordered his on June 2, it shipped on June 4, and will be delivered Tuesday....
It sounds like you may have gotten screwed...
EagleTalons
Master JB Welder
Forsyth, Montana
**** this sucks! I'ma call them up on Monday and annoy the hell out of them.
The flatty 5hp...I don't know how you knew it was a flatty btw... I started it on ether (lazy). Revved up then the pull start cord... Gets caught in the flywheel and makes the loudest screeching noise ever! Now its stuck fast in there and the stupid pull cover is riveted on... So I stuck the engine right back were I found it.
Kaptain Krunch
Pro Junk Collector
vermont
i'll take it :bannana:
Im the master of reality, thats how i knew it was a flatty :roflol:
EagleTalons
Master JB Welder
Forsyth, Montana
You have a lot of things here to take! :p
I've decided that if they don't ship me a clone after Tuesday. I'm going to fully cancel my order and get a TAV with the saved money.
I would enjoy the clone as they have ALOT of bolt on parts and I know where to find them. Plus I like how it looks.
~JM~
5HP B&S won't just drop into a DB-30. The fuel tank & rear fender will hit.
A 3.5HP B&S I/C engine will just make it, but a regular B&S 4HP won't clear.
Of course you could modify or remove the rear fender & have the clearance you need. Or a shorty fuel tank. A Tecumseh with the tank up front drops right in.
EagleTalons
Master JB Welder
Forsyth, Montana
Yeah....delivered today.
Eagle, any update on the status of your order?
Well what happened is I paid with a visa gift card and they don't know how to get money off of them..? Something stupid and they lied to me too about the order status. No more Harbor Freight.
The flatty runs fine now! Just regapping the coil and gonna look at the fly key while I'm at it.
Also this is a homemade doodlebug. I'll get ya a link to my good thread.
http://www.diygokarts.com/vb/showthread.php?t=3876
