Harbor Freight 2.5 carburetor jet
robbie
Osceola, Missouri
The 2.5 hp on my mini bike has a high flow air filter, and I think the jet needs to be drilled out just a little bit.
I suppose I could get it right by taking the carburetor to a tool shop and looking at all the drill bits until I find one that's just a tiny bit bigger than the jet. But I was wondering if anybody here had already measured the jet and drilled it out. If so, maybe you could tell me what size drill you used, and how well it worked out.
kendelrk
redneck engineer
westland michigan
its alot easier just to oder one for 12 $ off of affordablegokarts.com drilling isint always going to work right and you might **** up the jet, so i would reccomend getting one off of affordable go karts
r_chez_08
Should be in the shop...
Cornwall, UK
if you want to drill, buy a numbered drill set, eg: 78,79,80 etc. and drill with your fingers, not electric drill.
rob
robbie
Osceola, Missouri
Sounds like a good plan.
I haven't seen any jets for sale to fit this engine. The smallest one they sell parts for at Affordable Go Karts is the GX160, which is about twice the displacement of my engine. I don't suppose they would use the same jet...
I honestly don't know, but I doubt it. You could first buy the numbered drills and use them to find out what size you have, or if you look around online, you could probably find the service manual for the equivalent Honda GX engine, which would tell you.
robbie
Osceola, Missouri
I'm looking at the list on wikipedia, and I see that Honda has made a 49 cc, a 98 cc, and a 118 cc. The Harbor Freight engine is 79cc. I'm not sure exactly what it's a clone of, if anything.
r97
Measure twice cut once
Massachusetts, USA
not sure if or what its a clone of, if its a clone of anything that is. maybe an older model honda?
not any of the new ones, the clone is slant cylinder, these aren't,
http://engines.honda.com/models/displacement/0-99
EDIT: i suppose the gx120 looks similar, but much different hp and displacement, note the new "predator" clones kinda have a gx120 clone, but it has the displace ment of the gx100, hmmmm......
http://www.harborfreight.com/99-cc-ohv-horizontal-shaft-gas-engine-certified-for-all-states-except-california-68124.html
r_chez_08
Cornwall, UK
Have a look at the jet, it is likely to have a number on the bottom of it, with the size. This will give you an idea of where to start drilling.
Rob
robbie
Osceola, Missouri
There was no number on the jet. I opened the hole up very slightly with a torch tip cleaner. One of them was just a little bit too big, the other one was small enough to have space all around it. So I filed the hole out just a tiny bit and the engine runs a lot better now.
In case you guys want to know, that's one way to do it. Just take a little bit of metal off, reinstall it and try it. Repeat until it runs well. I got mine to run pretty good on the first try!
Bluethunder3320
nice! is it running a tad lean or rich?
look at the plug. if its caked on black, too rich. super clean and a little white, too lean.
robbie
Osceola, Missouri
It used to have a really finicky idle, and we had to keep bumping the throttle to keep it from dying. My son rode it around for about an hour this evening and everything was great. It never acted like it wanted to die at all.
I haven't looked at the plug yet.
