Hamilton Lightnin' Karts?
jray0517
Well yeah eventually theyll have their own and this will be mine but right now this is hig enough for me to sit them in my lap. And i can make it as fast as I want for myself at the same time.
jray0517
Just curious, what’s the tooth count on the axle sprocket, and if the engine has a clutch whats the tooth count on it? Definitely will need a TC/Torque Converter unless you’re creating a parking lot basher or neighborhood terrorizer.
60 tooth on the axle and 10 tooth on the Predator. It comes with a bare 3/4-inch horizontal shaft with a 3/16-inch keyway.
Honestly not sure what im going to do yet. First im gonna pull it apart and clean up the frame and such. Id like to upgrade the brake system which probably means an axle upgrade. Not planning on any racing or anything serious. Just a fun yard toy, but hopefully fast.
Staff Murderator
By the way, your brake drum appears to have walked sideways a little on the axle, and it twisted the brake band..(?). Despite their primitiveness, the band brakes work really well and are self energizing.
I will second that about the band brake. When aligned properly they work very good. No need to buy another axle or anything. Keep it simple. Clean up the drum ( or buy a new one if it's twisted ) and get a new band. They have brake lining material in them. Sort of like new brake shoes would have had on them on a car with drum brakes.
Staff Murderator
Pancho is right. No need to replace much of anything because “eww it’s rusty” and therefore “bad”. Everything can be refurbished with Mister 10K Rippems of Death (the angle grinder) and a wire wheel/wire cup ….plus flap discs and the 3M scotch brite abrasive things. I used to use a corded drill for the same purposes and it was just redickerous.
