Halp
Fluke
I was recently given a "Golf Cart" rear axle and want to build a three wheeler neighborhood cart for my Grand-Sons. I need help finding out what I got. It looks like an automobile differential with the pinion shaft oriented like an automobile too. It has what looks like a snowmobile centrifugal clutch mounted on the pinion stub.
Without a picture, what could you tell me about it?
Thanks in advance.
I think I have seen what you describe. Might even be a Dana. However- are you sure it's a centrifugal clutch? I'm pretty reasonable sure it's the driven portion of a CVT. Pics would really help.
Generally, golf cart axles are geared too low for use on a go kart. However- it may well be okay if the kids are young.
exenos
Project Nut
Toystory's definitely dead on with that being a driven from a cvt. Take a measurement across the top of the driven
Fluke
I took the unit off the pinion and measured the stub, it is a 3/4" splined stub I would like to join this with a 10 horse Briggs & Stratton horizontal engine. Could anyone steer me in the right direction to search for the correct drive unit?
Or better yet: Can anyone tell me what year and Mfg. used this type rear end?
Thanks.
jamyers
Buffalo Gap, TX
Are there ANY markings ANYWHERE on it?
I don't know golf-carts, but automotive axles are often stamped on the axle tubes...
I suspect it may be a Dana. Clean it thoroughly, and look for identifying markings. Also, take a good, clear picture of the cover from straight on. Often, the shape of the cover and bolt count are used to ID pumpkins.
Fluke
I've been looking at CVT units on eBay and noticed they all seem to have sprockets included in the kit. Anyone happen to know why the sprockets would be included? Could I just buy a driving hub to fit my engine shaft and buy a driven hub to fit my pinion shaft and then buy a belt to fit? Or are the belt sizes limited?
You are correct about ID'ing the differential and going with OEM parts.
Fluke
I went out to the shop which is a little cool today and wire brushed the pumpkin which has 10 bolts by the way. The only marking was on the rubber filler cap and that said "Spicer" on it.
TC's come with a sprocket. You cannot use the TC if you don't have one. You still need one to run your chain from the CVT to the axle sprocket.
Have a look at a couple of pics of how they work, and you will get the idea
jamyers
Buffalo Gap, TX
You could try and find the correct golf-cart CVT Driver unit, or if you use a karting CVT you could use a really short chain from the CVT sprocket to a same-size sprocket bolted somehow to the axle pinion.
