GY6 Wiring
qtband
St. Louis, MO
I bought this kart and the electrical is so hacked I need to replace and simplify.
I followed the diagram below for the CDI wiring with no problem. I'm on to wiring the rectifier/regulator and the wire colors don't match my diagram. The old harness was cut and hacked so bad I can't even trace the original wires.
Does anyone have any suggestions on how to wire this?
I have:
Pink, green and yellow from the stator.
Pink, green, yellow and red from the rectifier.
One red from the fusible link off the starter relay positive side.
Surely it can't be as easy as matching all the remaining wires, can it?
qtband
St. Louis, MO
OK, I completed the CDI & regulator wiring and the engine starts on a quick touch of the screwdriver across the starter relay. Great!
Now...I'm not sure how to wire the key switch and starter relay. I have a 3 wire key switch and 2 wires coming from the relay. Anybody able to decipher the schematic? I don't have any brake switches or anything else. Just a relay & switch. The last picture is the mess I started with.
anderkart
Surprise Arizona USA
One of those 2 starter relay wires needs to be grounded, and the other wire needs to get power to engage your starter relay. Polarity doesn't typically mater on these 2 wires since they're just activating an electro-magnet inside the relay. So you could permanently ground either of those relay terminals, then wire your ignition switch to send power to the other relay terminal when cranking.
Or, you could choose to trigger the starter relay with a ground signal from the ignition switch. (like the wiring diagram in your first post does). In that case, you could simply wire either one of the starter relay terminals to power, and then activate the starter relay with a ground signal from your ignition switch, or a push-button switch.
This second method might be the best option, because your Ignition system needs a ground signal to kill the engine...
Are the terminals on your 3-wire Ignition switch labeled, what do they say?
Does your Ignition switch have an Off/On, and then can you also feel a spring-loaded crank position as you turn it?
anderkart
10-4, Make sure you get an Ignition switch made for an electric start/magneto type ignition system, they're made to ground the ignition wire in the off position, to kill the engine.
We could wire a regular automotive type Ignition switch to crank your starter, but not kill your engine...
