Hmm..
that is odd... usually a quality belt last quite a while.
But maybe we need more info about the kart itself..
What exact engine are you running? (a 125, 150 or 250 cc version? long or short case...)
I know it SHOULD be the 150.. but maybe that was swapped in between owners?
If it still is a 150cc is it still the ORIGINAL engine or a replacement,
if a replacement, same mfg or just a generic one?
What are the chances that someone (you or PO) messed with the internal reduction by swapping the input gear?
different mfgs use different internal gearing.
Some are geared for two (small) wheel scooters, others are meant to be used in buggies with way larger wheels.. so it does matter what enigne and what internal gearing is used!
What is the rear wheel diameter and the chain reduction ratio?
Has it been changed?
If that thing is bone stock engine gearing and wheel-wise, check the clutch side as well,
a burr can shred the belt of course..
all sheaves must be smooth as a baby's butt:
no rust, no dirt no burrs no pitting...
and no "increase grip by rough sanding" either of course.. that's a stupid move anyways
And if that's also fine (everything's clean the clutch is functional [especially the return springs])
how about the side cover? is it tightly sealed and dust proof?
Or has it been left off to see the action?
And lastly.. belt..
if you buy a belt for 5-10 bucks I expect it to last as many minutes tbh..
So, find a good quality belt,
make sure to use the correct size as well
(it must not be too tight, else the clutch will eat it up in idle)
tough to tell from here...
and without pictures of the equipment even more so.
So, take a few pics for us
wheels, CVT [both pulleys], maybe show us a glimpse of the input gear,
and also chain and sprockets just to get an idea of about all of the transmission.
OH: and as usual:
Buggy "has to be used" as per the manual..
else the fun doesn't last...
so yeah... less donuts in the mud I guess
And lastly.. belt..
OH: and as usual:
