GY6 Connecting Rod
Joe-405
Enjoying New Projects
U.S.A.
No. They are press fit cranks with no way of removing the rod by itself. See pic............
Unless you can split your crank and repress it exactly the same.
65ShelbyClone
SoCal
It will be less expensive to replace the crank and rod as an assembly.
Yes the rod alone can be replaced, but like Joe said, it requires splitting the crank and then pressing it back together. It generally requires special fixturing to get the alignment very close followed by truing.
