GY6 Carb Help
Gadsden, AL
This is a Hammerhead GTS 150. It needed a coil and sat for about 8 months. I replaced the coil and plug. It will fire and sometimes run for a few seconds. So I assumed the carb was clogged with old gas and bought a new one. Installed new carb and fuel filter But still no change. I put new gas in, used an air hose to blow up through the fuel line into the tank. No change. Any ideas? This is strange. It was running fine before the coil died.
