Gy6 150
Nissinator1996
I have a gy6 150 but the ppl before me messed up the exhaust on the case so how do I mount it.....jb weld???
Jcotz
...wasn't there
NY
I'm pretty sure you would be able to just buy a replacement one if it was that screwed up. Pics would definitely help.
Nissinator1996
the holes on the engine block where the exhause mount is....is messed up someone broke bolts off in it and the tried to drill a separate hole so instead of have 2 holes it has 3 holes
rickyp8888
corpus christi Tx
its not going to be as easy as an bolt extractor seeing as they are studs and im pretty sure they are pressed in. so I say drill out the studs and use heli coil for new threads
klicky96
Sandusky, Ohio
Remember that post where ya'll were asking everyone what they would like on the forum? Well, lets add a like button! I would like that post ha.
Jake.B
California-USA
Yeah never have i seen pressed it exhaust studs. They break from rust most of the time. Just a peice of advise with the ez-out. If you have never used One before its a good idea to practice or ask i trusted friend or whatever that has.. You can ruin all your chances of getting it out (besides drilling) if you mess up to bad.
dumby
I almost never use "easy-out" anymore. The new Gator or Grabit ones work much better/easier.
