GXV160 three magnet flywheel question
cavfire
auburn, georgia
I picked up a GXV160 flywheel that has three magnets, and would like some verification on which one triggers the spark. My gut feeling is it's the middle one as the first magnet is very weak and the last magnet is weak and smaller as well. If that's the case the timing on it is retarded compared to the stock flywheel on the Hensim clone I have. Without busting out a degree wheel I'm eyeballing a 1/2" or better difference in the magnet.
cavfire
auburn, georgia
Yeah it's the flywheel out of lawnmowers with a blade brake. Seen it recommended before as it is aluminum, strong, and roughly 4 degrees advance. That's what is confusing me as this flywheel is retarded compared to the stock one. FWIW the GXV160 flywheel didn't seem to idle as smooth either. Other concern would be running hot from being too retarded. May lap the flywheel to the crank or just try a 8 degree key.
cavfire
auburn, georgia
Update for anyone who was wondering. The GXV160 flywheel, at least with my block, is timed at 20 deg btdc, and the oem flywheel is at 24 deg btdc. This actually coincides with one webpage I found that lists it at 20 deg btdc. Through AGK and various forum posts there is info out there that states it advances timing by 4 degrees, but it looks like the GXV160 flywheel keeps factory GX200 timing and some of the clones at least have adopted GX160 timing. I'll still use it after I file the key as it lighter, stronger, and no chance of coil dropping in.
http://outdoorpowerinfo.com/engine_specs/honda_ign_timing.asp
