GX390 Clone only runs on choke
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
With a common title, you would think I'd be giving the usual explanation where I spray some carb cleaner and the engine runs. Unfortunately, things aren't that simple this time. Long story short, I'm fixin this generator which sat for years and is in near-new condition with 3 hours on the counter. So the jet got stripped and I had to replace it with this carburetor. It finally came in the mail yesterday, and I put it on. Last night, after everything was installed, the engine cranked up with a hard pull, and began surging. So today, I made new gaskets for each side of the black spacer between the cylinder head and carburetor, cleaned plenty of rust out of the gas tank with a chain and muratic acid which burns my ankles to think about, and played with the fuel mix screw incessantly (I set it at 1 1/2 turns outward, and messed with it at half turns in and out over and over) all with no luck. One of the troubleshooting methods fixed the surging problem, but now it only runs on choke for about 30 seconds before it's dying out.
Now this is an ignorant question, but does it matter if I have the air filter housing in place? Any engine I've ever ran w/o the housing has ran normal. On choke, it runs around 2900 RPM, but the second you open the choke plate in the slightest bit, it makes that gurgling sound. The old carb had the fuel cutoff solenoid, but this one didn't come with the bowl. I can always use the old bowl and nut, but testing the solenoid is the least of my concern right now. I took the jet and tube out and they looked brand new as they should. I made sure there were no rust particles also. The choke lever is different on this carb, so I must find a way to rig a new lever, but until then, I need to get it to run first. The lever with the choke hose is always pushed in since I have no use for it with the new choke lever. So now, I shall sleep, and hopefully I'll be ready for the challenge tomorrow. If anyone has ANY suggestion, share it. Remember, it'll make your post count go up. ;)
Brandon1023
needs an oil change
So now I tried my 420 Predator carb on it and it ran decent with a little bit of surging which I'm expecting the air filter to fix by creating enough air resistance. The second I put the one from eBay back on, the thing started frustrating me again. The next step is for me to contact the seller, and ship it back cuz this is B.S. at its finest.
Nodroz
Belgium (Europe)
I don't fully understand. The engine will run fine with the 420 Predator carb on it, but it won't run fine with a brand new GX340 carb?
Maybe the needle settings aren't good on the new carb?
Brandon1023
needs an oil change
That's exactly the problem.
Now that I'm laying this all out in words, I think I misunderstood a lot. Those cheap chinese guys who made this generator stuck "11 HP" on the recoil label. However, on the shroud's label, I believe it says 389 cc which means it's a 13 HP engine. Right? Guess they got me in the posting title and the sticker on the recoil starter. I just saw both of them and didn't question the ccs. Guess I'll be returning this one to eBay for once p: . I guess it only works on choke since it can provide just enough fuel to keep the engine running? Could I make the jet larger allowing for more fuel delivery? It has a needle setting, too, but I kept it at 1 1/2 turns outward.
Brandon1023
needs an oil change
Don't think so. Either way, the carb doesn't work with it. Guess I'll tell the ppl on eBay. Simple mistake that can be avoided, be careful when buying parts, cuz you can easily be wrong !
You can re-jet, but I'm not sure that it's the solution. The 390 may have a larger venturi than the 340, and I'm afraid I don't know for sure. The thing is, at idle, the main jet doesn't do anything! You'd nee to increase the size of the pilot jet at the very least, and that still doesn't guarantee that the venturi size is correct.
Brandon1023
needs an oil change
This was put on to a generator with a fixed speed at 3600. When the generator is off, it's at WOT until the governor comes and kicks it down. I'm not going to mess with it. I'll send it back on Monday and ask if I can get a gx390 carb for my 420 now.
How is it that it's a 390, but rated at 11 HP?
Actually, the rating requirements changed within the last year or two. I did notice sometime back that the GX340's were now rated at 9hp, instead of the usual 11. There might have been some sort of government pressure to rate them more realistically, or perhaps with newer, harsher EPA rules, they lost some power. I don't know for sure, but I did notice.
