Brandon1023
needs an oil change
With a common title, you would think I'd be giving the usual explanation where I spray some carb cleaner and the engine runs. Unfortunately, things aren't that simple this time. Long story short, I'm fixin this generator which sat for years and is in near-new condition with 3 hours on the counter. So the jet got stripped and I had to replace it with this carburetor. It finally came in the mail yesterday, and I put it on. Last night, after everything was installed, the engine cranked up with a hard pull, and began surging. So today, I made new gaskets for each side of the black spacer between the cylinder head and carburetor, cleaned plenty of rust out of the gas tank with a chain and muratic acid which burns my ankles to think about, and played with the fuel mix screw incessantly (I set it at 1 1/2 turns outward, and messed with it at half turns in and out over and over) all with no luck. One of the troubleshooting methods fixed the surging problem, but now it only runs on choke for about 30 seconds before it's dying out.
Now this is an ignorant question, but does it matter if I have the air filter housing in place? Any engine I've ever ran w/o the housing has ran normal. On choke, it runs around 2900 RPM, but the second you open the choke plate in the slightest bit, it makes that gurgling sound. The old carb had the fuel cutoff solenoid, but this one didn't come with the bowl. I can always use the old bowl and nut, but testing the solenoid is the least of my concern right now. I took the jet and tube out and they looked brand new as they should. I made sure there were no rust particles also. The choke lever is different on this carb, so I must find a way to rig a new lever, but until then, I need to get it to run first. The lever with the choke hose is always pushed in since I have no use for it with the new choke lever. So now, I shall sleep, and hopefully I'll be ready for the challenge tomorrow. If anyone has ANY suggestion, share it. Remember, it'll make your post count go up.
