gman3850
well sense i already have everything lined up on my kart instead of buying a built vc460 im just going to be building my gx390. been running the engine on and off one of my buddies cart this summer and it fiannly started loosing power, diag was low compression so it it getting to be built.
so this is what i plan on doing
gx390 block
p&p head
1.3 rockers
manton push rods
65lb springs
aluminum retainers
.020 head gasket
new piston
arc rod
69mm stroker crank
246 dur 260 lift cam
billet adjustable flywheel
30mm cvk carb w/ accel pump
now my question on this is when doing the 69 stroker crank how much needs to be cut off the top of the piston to be able to work?
gx390 block
p&p head
1.3 rockers
manton push rods
65lb springs
aluminum retainers
.020 head gasket
new piston
arc rod
69mm stroker crank
